I have just moved from a mini4 to a mini6. mini4 with iOS 14 became unusable because of video lag. However old mini2 with iOS 12 worked OK. mini6 is very powerful i.e. no video lag, caching of video on, photo sync on and I can record the screen too. Screen brightness is the same as the mini4. Sadly it is expensive, especially the 256G memory one.1. What is the single BEST display device for the Air2S?
2. What is the best BANG FOR THE BUCK display (phones excluded)?
3. What model Ipod Mini works best?
Good feedback, question re the Tripltek @MA2 317 . . .
You are using the Air 2 controller, do you need a special mount for that or does it fit in the clamp area ok ?
I have older M1P and Spark drones, where the controllers fit the ipad mini 4 (and 5) in the arms just fine.
I know you have the Spark too, did you ever try the Tripltek in those arms by chance ?
I don't think it will fit, as the mini 4 is a bit of a squeeze, and that screen is 7.9cm, the Tripltek 8".
Just thinking, I might look for a Tripltek myself if it fits the arms ok . . . I do have a Lifthor mount I could use, and assume that would work with the 8" anyway, but very quick to just fly the mini 4 in the controller arms.
MA2 317" data-source="post: 1323146" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Thanks for the feedback and great photos, much appreciatedThe Tripltek is too big for the Spark controller and it sort of fits the tablet holder I used when flying with the mini 4 and the Spark.
View attachment 136618View attachment 136619
The Tripltek will fit the MA2 controller with one of the adapters similar to the one used for the mini tablets.
I had one of the adapters but decided to purchase the LifThor Baldur rig since the Tripltek is heavy and I was afraid I may damage the antenna mast of the remote using the adapter.
but a bit of extra time setting up, not a major problem except for short flights.
I have the Lifthor and quit using it. Too bulky. I use this and love it: Tripltek Tablet adapter pack! | MysiteThanks for the feedback and great photos, much appreciated
Looks like if I take it on it’s be Lifthor mount needed, not a deal breaker but a bit of extra time setting up, not a major problem except for short flights.
It is quick, easy to use and stores well. I leave the lanyard adapter installed all the time.
While I don't have the Tripltek, my Lenovo 10 works great with the Skyreat adapter. It's aluminum (most of it) and pretty lightweight. Fits nicely on the Air2 RC as well.Yes, I too find that with the Lifthor design, but it is sturdy and I can see the telemetry on both controller and device on the older M1P equipment.
Thanks for the link though, always good to know what's out there and someone here might be looking too.
1. Tripltek seems to win hands down - yet very pricey - so that is a consideration for some.1. What is the single BEST display device for the Air2S?
2. 1,000 different answers from a 1,000 people.
Then you are going to want either a Tripltek 7 or Tripltek 8.I'm going to want a larger screen than a phone will give me, so what I'm searching for is a dedicated device to use with the Air2S, and I won't be purchasing a phone data plan for it. My main concerns are brightness and comparability.
At your age (121), I would think you'd want the biggest brightest screen you could find. I started with a 5.5" Crystalsky and while it was bright, it was too small. The Smart Controller is the same size and like the CS it is old technology. For the Fly app, I bought the original Tripltek 7" when it first came out. I will probably upgrade to the 8" Tripltek next spring. Newer tech, larger screen, can be used as a tablet or a drone display. Can't do that with the Smart Controller. But the choice is up to you. iPad with larger screen but 500 nits, SC with small screen but 1000 nits or Tripltek with 7" or 8" screen and 1200 nits plus usage as a tablet on the side.So for $450 more when I buy the Air2S package, I can get the Mavic Smart Controller (5 inch screen) or I can spend $675 for the Tripltek 7 or $800 for the Tripletek 8.
So here's my question. Is the Tripletek really $250 - $350 better than the Mavic smart Controller?
Owning the SC - I'd have to say yes, a larger brighter screen is worth a couple hundred dollars.So for $450 more when I buy the Air2S package, I can get the Mavic Smart Controller (5 inch screen) or I can spend $675 for the Tripltek 7 or $800 for the Tripletek 8.
The convenience of an all in one controller/screen like the SC is real
