You are right in that it’s related to terrain or obstacle height AMSL , but it shows the safest height to clear that terrain at 300’ above it- the actual height of the terrain or highest obstacles in that area are -300’ below that number.These are called maximum elevation figures (MEF) shown in quadrangles bonded by ticked lat/long lines.
The MEF are represented in thousands and hundreds of feet AMSL and are based on information concerning the highest elevation in its quadrangle including terrain and constructions (trees, towers, antennas).
I've attached a screenshot of a chart with certain numbers circled. What do they mean, and are they measured in MSL or AGL?
Thanks!
3160+ 300’ = 3460 AMSLIt's the Maximum Elevation Figure for that quadrangle, it's the highest point in that quadrangle, rounded up to the nearest hundred, and 300 feet is added to that. The highest point's dot is slightly bigger than the other elevation dots. It's not meant to be a "safe" alitude by any means. Dig this:
Those numbers are used for planning purposes by pilots flying cross-county, who would typically want to fly a couple of thousand feet over the mountains. They might also be used in other situations like a night flight where you find that you don't have as much fuel as you thought and need to divert. Knowing the elevation of the highest obstacle nearby is useful in those cases, and in neither of these cases would a pilot be looking to "barely" miss the mountain top. Pilots flying within a few hundred feet of mountain tops on purpose don't pay attention to the MEF number because they are watching the mountain under them, or beside them, or looking at the mountain's elevation on the chart as they approach the mountain.Flying at 3500’ AMSL would clear the highest point by 340’
Ok, the term I used should have been the “minimum” altitude...obviously any pilot would add a few extra 100’ to that as well to be at least 500’ over it.
