Calibration via DJI Assistant 2
linux_guy
Toronto canada
HI, I've tried this several times and same result each time. I'm trying to do the calibration via DJI Assistant, the front /back/sides etc, go through all that successfully, at the end it says . "Calculating ... Calibration information collected. Calibrating" . but it hangs, I've waited over half hour and no change. Please see the screenshot, Anyone know what's going on?
I have exactly the same problem on one computer, using a different computer I get a "time out" message immediately after the 4 corners are detected, BUT on a 12 year old computer (maybe older) I was able to painfully complete the process. (The old computer is really slow!) The computers that the process failed on are only 3 - 8 months old, both are running Window 10 Pro. The old computer is running Window 10 Home. The DJI Assistant app needs some attention!!!
Reactions: TTP
Welcome to the forum from the deserts of Arizona!
following the directions correctly is extremely important. Screen size is also important. Try something w/o Win 10 next time.
I have commented on this problem before, my opinion is still that it is a lousy program that DJI should redesign so that it will be easy and smooth to do sensor calibration.
SK farming
