Camera vibration
Dunrod
My Mavic's gimbal and camera suddenly started to go nuts on start up, this would stop and then repeat every 30 secs or so (my Mavic has never had any crashes or hard landings and has only been flown about 8 times)
I replaced the ribbon and put it all back together and it appeared to fix it, however now the mavic won't auto calibrate (stuck on 5%) and the gimbal and camera has a micro vibration causing the video feed to be shakey when stationary on the ground.
Has anybody experienced this and figured out what causes it? Cheers
I know this is an old thread but I cruise for unanswered threads to see if I can help sometimes. Did you ever solve your calibration issue? If not, here is a thread that might help.
Controller Calibration - how?
No I never got it fixed, I emailed DJI directly a couple of months ago about the problem, asking if they could repair it under waranty or if I could buy a new camera & gimbal but they didn't have the decency to reply to me.
I'll give the link you attached a go and see if it works.
Many thanks
sscott062
