It won’t shut off and it’s blinking yellow light really fast and I cannot get the battery out to shut it down any suggestions
It's starting to smell like something is burning. Not good.Seems like your battery might be one of the defective ones that has "gone critical". I suggest you try to pry it out, otherwise it will melt your drone. Regardless, contact DJI because you should be able to swap it all out under warranty.
It's not turning off and the battery is not coming out. Have tried to get it out about 10 times now.First power off before you remove the battery. One tap, release another tap and hold for a few seconds longer and then release.
The two release buttons on the side of your battery push inwards at the same time. Gently wiggle your battery at the same time while pushing inwards on the battery release buttons. Don't force it, be gentle.
Could that be true? Surely not. I am becoming worried about my MA2 as this is not the first report of melting batteries.looks like that sharpie texta writing caused an abnormality on the battery housing causing the melt down...
I think he is jesting buddy,hope they sort it fast ,too many of these burning all look the same.have you just got the drone ?Could that be true? Surely not. I am becoming worried about my MA2 as this is not the first report of melting batteries.
I hope DJI reads these posts and issues a statement to alleviate my fears.
Chernobyl like ......... ?looks like that sharpie texta writing caused an abnormality on the battery housing causing the melt down...
Just curious since it is summer in the states and extremely hot in many parts of the country, were you flying in excessive ambient heat where you are and did you fly for a long time prior to that incident? Where I am it is in the 90’s regularly and I have felt the batteries were getting drained a bit quicker than I recall. Thus the curiosity. I am genuinely sorry you had this experience.
