Can anyone explain this? gpsHealth drop from 5 to 0 with 18 sats locked
DroneX
As you can see below, I started a point of interest and within seconds it exited and went into ATTI mode. There were 18 sats locked and gpsHealth suddenly drops to 1 for no reason? This is a new mavic manufactured April 27 2017. Any ideas how to prevent this?
1bjbl
1bjbl
What was the physical location like? Was there a lot of metal near by that could have reflected the signals?
I had that happen to me. Sent back to DJI for replacement.
Were you in sports mode ? Potentially the infamous interference due to non-twisted wires on rear GPS unit?
No wasn't in sports mode. Will keep an eye on it. Went for a flight yesterday with no issues, will try a point of interest again soon and see if it occurs again. Thankfully purchased from Amazon and still have a couple of weeks if I need to return it.
Might want to look at compass data to see if you can see something abnormal at that time.
I had also issue with gpshealt dropping to 0 regardless of high number of satellites reported. I have theory that is because strong inconsistency between GPS signal and compass/gyro data from the other sensors and internal software to avoid fly away dropping gpshealt variable to switch to ATTI. I don't have enough supporting evidence except that this always happen after FW
Update without IMU and compass calibration. Once system was calibrated no issues.
Reactions: DroneX
Will try recalibrating everything as all I did was the compass after unboxing it. Will let you all know how it goes
RTLflyer
