Can this be Gimbal part be repaired easily, or does it need to be sent into DJI
Jim Rich
Problem?
Gimbal vibration error, vibration is very noticable.
Was unit in a crash?
Yes
What have you tried so far?
IMU recalibration and DJI Assistant calibration and update to latest firmware. Physical inspection revealed damage to the Gimbal, see picture. Can this damage be repaired at home? Could the arm be pried back a little bit to allow the gimbal to operate freely?
What device are you using ( iphone , ipad, Samsung , etc)?
IPAD Mini
What firmware are you running ( aircraft, remote controller)?
Latest as of 10/14/2018
What Go app version are you using?
4.3.3
Any modification?
(if so what)
No
Did you change anything or install any apps? (if so what)
No
Do you have a video or pictures of the problem? (if so post link)
Yes
That seems to be just the little plastic cover that is damaged, you can be a new one for a few cent. Cannot see if the ribbon cable is damaged
A YouTube video would help. Without any visual evidence, I would say that your motor assembly might be damaged.
Is it possible that the misaligned case is causing friction and the vibration might quit when he realigns it?
Upon closer inspection and after comparing it with a working drone, the damage may be more serious.
It is not a misaligned case, after looking at a few forums, that is the first thing that I checked.
I had the same damage
Send it to a Master (Thunderdrone) to look it over
Might have more going then a novice can see when it gets opened.
Rob (thunderdrone) is a skilled tech quick and very reasonable and has a solid reputation
......cR
Reactions: Former Member
andyt19852
