Changing the default file names?
calltrex
CA
Is there a way to change the default file names it automatically makes.
Want to remove the dji part
That I know of, not whilst on the drone. However, on your computer run them en masse through something like "Bulk Rename Utility". In Bulk Rename Utility I would do that using the 'remove first x characters' route.
Reactions: THE CYBORG
You can rename your image files after you copy them to your computer.
But there's no way to change the filenames the camera saves.
seaphotos
