Charleston, SC checking in
Welcome to the forum! :)
Greetings from Birmingham Alabama USA, welcome to the forum!
New to this forum, I have a Mavic 2 pro and a smart controller that has been in climate controlled storage for 2 years due to me traveling alot for work.
You say that your "Mavic 2 pro and a smart controller that has been in climate controlled storage for 2 years due to me traveling a lot for work." I hope your batteries are recoverable… Smart batteries do not recover very well. I recently posted a reminder to keep your batteries charged up…
Well, let's hope your batteries recover…
As a recently Newly returning Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are still required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in South Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 2 Pro/Zoom, including the User Manual.
Happy Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
KiKiHUN
