Always check props for cracks, damage, and proper attachment, before takeoff. Also check the hinges to make sure they are not going to fail. For years, I never did. I will now.
Today, I flew a routine recreational flight with a MAVIC 3, when suddenly, my drone's video feed indicated it was out of control and falling. It fell out of my line of sight and thus lost signal after nearing ground level. WHY OR HOW DID THIS HAPPEN?
The day before this, I accidently skimmed some small tree branches with my props. The drone almost fell but recovered. I neglected to inspect the props and their attachment to the drone after this event as the drone was still flying normally. I suspect a blade may have cracked slightly or it's pivot point became damaged. I may have seen this if I took the time to check the blades individually.
The next day, I assume, one of my props broke and ripped itself off the drone. This was made evident when I recovered my drone. One prop was missing, and the spring was warped out of place, as if the prop was forcefully ripped off the drone. I assume one blade of the prop pair snapped or became unhinged, causing an imbalance, thus ripping the prop off.
The drone crashed near the edge of a main roadway in the tall grass and brush. I was lucky I did not hit a car. I followed the rule, you can cross traffic, but don't fly or hover above it. I was flying down the roadway, 20 ft off to the side at about 100ft altitude.
Luckily, the crash only caused cosmetic damage. The drone had a cushy , soft crash landing from 120ft into tall, bent, matted dry grass.
Finding it worried me. But, I had 2 drone alarm beacons attached to it. They were flashing and creating a high-pitched beeping sound. The drone made its way under the grass somewhat. I would have never found it if those beacons weren't blaring away, I just had to walk toward the noise. Once close enough I saw the flashing lights.
I no longer have care refresh on that drone, so I purchased personal property insurance through State Farm for 65 dollars per year. If it did suffer irreparable damage, I would have been covered. I was lucky though. No claim had to be made this day.
