Checking IMU & Compass status lost function?
Ronpan99
Hi,
I haven't flown in since 6/16/17 until today, but has anyone lost the function to check the compass & IMU status from the start-up Aircraft status. They both say Good, but I am unable to check them and look at the status numbers. I'm using version (v4.1.2).
Is there a way to get it back or to look at them from a different pathway?
Thanks,
Hi,
Thanks,
Shure.
Just tap this area when connected:
Shure.
Thanks I posted on the General forum as well with same topic. This time I added a pic.
I'm unable to get to the status function as before. I believe there use to be another section on the compass and IMU where I can check the numbers.
Re install the Go App.
All should be back to normal.
Give it a try! Worked for me!
Reactions: Ronpan99
Three dots on upper right.
Tap the drone Icon.
Scroll to bottom: Tap Advanced settings
Halfway down the page: Sensors
There you will find IMU, Gyro, and Compass conditions.
You'll only be able to calibrate the compass from the Aircraft Status section when DJI GO detects a compass error and/or thinks the compass needs to be calibrated. The compass can always be calibrated from the following section of DJI GO:
NY NICKY
