Cobber 1 from Taranaki New Zealand
Cobber 1
Hi I recently purchased a Mini 4 pro with the RC2 Controller. I've had 3 flights but have been grounded due to high winds. I want to video & take photos of landscapes & my love for the Yamaha waverunner Jetski which I've had 6 of over 30 years . Can't wait to get competent in flying & tracking our jetski club days.
Talk soon
Cobber 1
Talk soon
Cobber 1
You might consider getting the Mini 4 Pro Wet Suit to take the drone out with you on the Water, We take it out the Air 2S on the Jet ski .
Phantomrain.org
Gear to fly in the Rain , land on the Water.
Talk soon
Cobber 1
Im also new here. Welcome. I have purchased mini4 pro also. Cant wait for it to arrive.
Welcome to the forum! :)
Since you live in New Zealand, there are specific laws and rules for you to follow, please check to ensure these are current.
Not to be a kill joy but you might want to learn to fly your drone before you take it swimming… Even if you have flown Drones before, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 4 Pro, including the User Manual.
Fly On and Fly Safe…
Wow & yes it won't be over water for some time & very aware of the rules in New Zealand.
Reactions: LoudThunder
Overspeed
