- Joined
- Jan 3, 2019
- Messages
- 1
- Reactions
- 0
In addition to the suggestions above, make sure you're running a mobile device that can handle cold temperatures and keep your hands warm
That would be a good thing to try if it cannot handle the cold.Guess I could put a case on it
I strongly recommend staying within DJI's posted flying temperatures for the M2 and make sure you keep the batteries warm. Also keep in mind flying outside of this range voids your DJI Refresh if you have it.
This thread may be of interest as well, issues with people flying when it's too cold are not uncommon and I suggest you ignore anecdotal comments like "I flew once at X temp. and it was fine".
Motor shut down in cold weather??
Do the logs record air temperature?
