B
there is a setting for that in the controller ? if so where about ?Is the controller charging you conected mobile ??
If it is disable charging
S7 Edge Australian Optus - latest firmware. I get about 3 flights. The phone doesn't even show its charging. I am using the USB bottom port btw.
I guess this is the sacrifice for using a smaller controller. Best bet is to carry a MAVIC Battery bank adaptor or get an external power source.
I have 3 batts in total. If I have to, I will use the almost depleted batts with the Mavic battery bank adaptor to charge the controller.The Mavic Battery to Power Bank Adaptor uses a Mavic battery to charge your phone, tablet or the RC. So you're trading running down a charged flying battery to recharge your device or RC. Sounds like something you wouldn't want to do unless you just really needed to get one more flight in or you have a whole bag full of extra Mavic batteries. Or is there some other scenario I'm missing?
Mine too. I'm using an S7 Edge and it shows that it is charging. I'm just planning on using the depleted batteries to charge the controller during battery switch overs or else bring a PowerBank and charge in between. Definitely need a good RC charge!Hi all
The battery on my Controller seems to run down very quickly and seems to need to be recharged after only 2-3 flights.
(Yet on the forums most people say they get about 6 full flights from 1 charge)
Anyone else experienced a similar issue, or know of a solution please?
Thanks Yes, on the advice given, it was just a waiting game. As the Controller battery has now been recharged several times, Im getting 5-6 flights out if it before the next recharge.
Am also now using a 7" Bush Spira B2 Android Tablet, which works a treat, fits perfectly within the controller arms, and has a SUPERBRIGHT screen for outdoors use.
Am a happy chappy now
In the same exact boat as you. Careful with your s7e, I dropped mine when removing from the case before a flight last weekend, sent some lightning breaks through both sides of the screen... If only the RC could support phones with cases... sigh. At least I have phone insurance I guess. Not keen on the whole process after going through about 5 different phones in the past couple months due to the note7 fiasco with Optus.S7 Edge Australian Optus - latest firmware. I get about 3 flights. The phone doesn't even show its charging. I am using the USB bottom port btw.
Sent from my SM-G935F using Tapatalk
I recommend buying a cheap used Note 4 or 5 and just leaving it attached. Makes setting up way easier too. Then you can just install DJI GO without other apps slowing it down.In the same exact boat as you. Careful with your s7e, I dropped mine when removing from the case before a flight last weekend, sent some lightning breaks through both sides of the screen... If only the RC could support phones with cases... sigh. At least I have phone insurance I guess. Not keen on the whole process after going through about 5 different phones in the past couple months due to the note7 fiasco with Optus.
