I only watched the first one- camping trip. Too much jerking around, transition bubble effect annoying and inappropriate (do a cross fade). Edit out the yaws. Stick to a flight plan. The flights did not tell a story- first here, then there, and where ever. Where is the this thing going to next? Needs a lot of work on this.
Hi Romanbydrone,Hi Jack43
Think you definitely nailed it with the edit!
Thanks Paul, I DO like your edit. Awesome music too. Where did you get the music? I'll try to reduce the bubble effects, although the next 2 will have them because I already finished the edits. The yaw is nearly impossible to smooth out with the mini, smooth enough in normal speed, but jerky with the higher speed after editing. I am hoping DJI provides for some type of Yaw smoothness on a future update, similar to what they provided on the Air 2, that would allow smooth panning.Hi Paleomanjim
I played a little bit around with your Nevada Roadside clip. Some tipps: the music is way to bouncing, it does not fit with the smooth images. Have you ever seen such "bubble effects" in a professional video? I don´t think so That doesn´t really look god! The better way is to use a quite normal dissolve effect. You also should try to make smoother movements when changing direction with the Mini.Of course it´s a question of practice! Did you fly in C modus?
I choosed anothe music which fits better to the desertic images. ( BTW I like very much the landscape!!) What dou you think about it? Hopefully you like it
cheers Paul
Very positive criticism. Please share with me one of your videos so that I may see what a quality video should look like.I only watched the first one- camping trip. Too much jerking around, transition bubble effect annoying and inappropriate (do a cross fade). Edit out the yaws. Stick to a flight plan. The flights did not tell a story- first here, then there, and where ever. Where is the this thing going to next? Needs a lot of work on this.
iMovie on MacBook, thanks.Nice videos. What video editing program do you use?
Yep, I fly 3D planes using thumb and first finger on the left stick, much better control for me than thumb only. The mini however would benefit from a future update to reduce Yaw sensitivity, it is just way too sensitive as it it now. Overall, that is my only complaint about the Mini, it is fantastic otherwise. My guess is they will add that sometime in the futureI've found if I hold the stick at the base and pinch them with my thumb and first finger I can yaw much smoother and slower.
Highway 318 just below Lund in Eastern Nevada. Very desolate area where most folks are driving 85mph to get through it as quickly as possible! I like this area though, always something different to see if one just looks.....Nice ! Where in Nevada is this ?
Hi Jim,Thanks
