Cracked FR Leg Antenna - Options/Opinions?
MavicHavic2019
Hi All!
Well, it happened...Crash!
My drone: Mavic Pro Platinum
Long story short, I managed to break the front-right leg and cracked the upper (closer to the body of the drone than the ground) portion of the antenna. I would like to know what my options are.
  1. Is it ok to use (just get a new leg)?
  2. Glue back together and get a new leg?
  3. Replace the antenna only with a new leg?
  4. Buy a new arm?
  5. Or other?
Also, any recommendations for purchasing new parts?
if it were me i would change the antenna and the leg that houses it ,just check the folding arm for any damage where it hinges to the body it might be easier to replace the whole arm if it comes complete with the antenna fitted what ever way you go i believe there will be some soldering needed
I cracked two legs by pure harmonic vibration from leg extensions. I took them off, no more cracks. Tried gluing with cyanoacrylate. Doesn't hold. So I just bought two new legs.
Now in the case that you smooshed your drone, I like what @old man mavic said.
Reactions: old man mavic
Well, it's hard to swallow, but perhaps a new arm is the best course of action. I am not great at soldering...I suppose now is the time to learn. I assume clean all connections well and flux everything is key?
Thank you, for your suggestions!
Prob less than $100 repair
click here for your free inspection free shipping BOTH WAYS you only pay if we fix
If you want to fix yourself you can buy the arm here but please be careful w/ the core board ($300 part) when soldering
I purchased a new arm with leg and motor. I haven't had a chance to work on it yet. It will require soldering. I intend to practice soldering on other circuit boards prior to working on the Mavic.
Reactions: Skyflyer129
Me too!! I do not use those anymore over a year now. No cracks!!
Reactions: RadioFlyerMan
Well I’m glad I did a forum search about retracted legs on Mavics, I was all ready to purchase. But, now I’m rethinking that after reading through this thread. Thanks for posting.
Blue skies.
nikdajsn
