DJI Go 4 map/radar question
HeliDog
Lol, i'll try again. I'm curious what the blue push pins are for and where they are shown in Docs. Pls see pic.
It does seem that a little blue pin will appear wherever you tap the map. You'll only get one pin on the map, and if you tap somewhere else, it will disappear from there, and appear where you just tapped instead. it's useful if you want to mark a place and zoom in on it ... or - pin the last known point that you lost your drone??
Reactions: HeliDog
I believe that pin shows you the airspace you are flying through.
The pin appears wherever you tap your finger on the map view, if you are flying there or not. It just seems to be a reference point in case you need to highlight something.
Yes you are absolutely correct. If you zoom out and tap your finger on the map view the only visible change I have observed is the highlight of a change to a new airspace if there is one.
Stormsignal
