DJI Mavic Pro does not support NTFS on SD card
richtroy
None of my home entertainment components seem to be able to read exFAT from the 64 GB SD card I use with the Mavic Pro.
I have the Roku Ultra, an LG OLED TV, and an Asus wireless access point with a media server. None of them read exFAT.
I tried formatting the SD card to NTFS. The Mavic Pro complained it could not read it.
Looks like I will have to transfer content from the Mavic Pro through another mechanism.
Most recent embedded devices read ExFAT, but not all.
Nearly none will read NTFS.
You can try FAT32, but you will have to use a card that's 32GB max.
Reactions: Xtreme Drone Pilot
Same problem here, smart TV won't read the bigger card but did fine with the smaller stock card. If anyone comes up with a solution let me know because I would really like to pop the bigger card onto my 4K TV to watch video right away.
If the TV can't read ExFAT, that's it. Sometimes there's no solution.
"DJI Mavic Pro does not support NTFS on SD card" = "DJI Mavic Pro cannot run my Playstation games!"
What is the default format used by Mavic Platinum? NTFS, FAT32 or EXTFAT?
Actually man can format larger SD cards to FAT32 too and there is a big chance that the device will be able to read it. Mavic is able of it.
if you can read, two posts above yours is said, that Mavics cannot read NTFS and of course it's valid for MPPs too
there is no such a thing as "default format used by Mavic Platinum"
in general all cards <= 32 GB are formatted to FAT32 and larger cards to exFAT, it doesn't matter what kind of device is used for formatting
there are however specialized applications that can format any SD card to whatever filesystem you like
nirjhara
