Whilst bored i just took a look through my rc and found the image below, for some reason it says zero flight time, but if you look at the time in the image after you'll see i've flown plenty.
Any ideas as to why its at zero?
Cheers.
Have you tried logging out of the app and then back in? Also try to clear all data including cache before logging out. When you log back in then sync flight logs again and it should populate.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
