Do you store/carry your tablet in your hard case?
Mtb Uas
Newcastle, Ca
I have the fly more package and will be getting a hard case to transport the Mav when I travel. I want to be able to also store/carry my iPad Air in the hard case. I've seen other threads showing iPad mini's in hard cases where they fit them vertically between layers of the pick/pluck foam. With the iPad Air(or other similar sized tablet) being about 1.5in wider vs the mini do you use a hard case that is wide enough to accommodate and store the iPad vertically or do you store it horizontally? If horizontally how do you store and protect it?
I store iPad Mini 4 horizontally in my hard case. I shaved about 1/4 inch of foam away in the spot that I store the iPad to make a recessed area to hold it in place. I'll try to send a photo when I get a chance.
Case Club Cases has an outer case than many other companies are using for there case.. Case Club has a different insert for the case.. In the lid. there is a foam cover that can pull off and behind is a compartment for an iPad.. I put a iPad mini in it with no problem with extra room I'm pretty sure a full size iPad will fit. It will also handle many other items.. They have a web site DJI Mavic Drone Case | Case Club
I'm happy with mine.
Reactions: Speedy
Nice case and good solution for tablet..
Reactions: Rnl
https://www.amazon.com/gp/product/B01M8HWEVW/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
I use this case and remove the left third(its removable) and place my Nexus 7 under the foam and then replace the pull out. Plenty of room for the tablet.
I was thinking about this one so I can carry my tablet what do you think?
https://www.amazon.com/dp/B071GFCM9...locphy=9011863&hvtargid=pla-366618639772&th=1
Shop around, you can find very similar cases on Amazon for cheaper.... I have one that is almost identical to that one, and yes, I carry a tablet/phone in that pocket. If you are really worried, buy a cheap padded sleeve for the tablet. It won't add much bulk, and will still be able to fit into that pocket.
Use a case purchased at HD to store MP fly more. Have iPad mini in case. Still have room for other contraband
i have a hard case and inside the top lid it has a pouch to store goodies which is gonna house my tablet
Reactions: Timecode
I just lay mine on the left side of my case and the foam holds it in place
Stephen King
