"Downlink data connection lost" once every 30 seconds, lasting 2 seconds
ecolier
UK
Bought a new DJI Mavic Mini this week, first tried some indoor flights without SD card and it kept disconnecting (but reconnecting within a second or two). Thought this is because I'm very close to it.
Took it outside today, again without SD card and recorded direct to phone (at 720p). The longest video I have is 26 seconds (interestingly there were 3 videos that's 26 seconds long) before it disconnects. It has never failed to reconnect though, is this normal?
Example of flight:
A00m 00s0.0 ft0 ftModeMode changed to Motors_Started
B00m 00s0.0 ft0 ftWarningCompass error. Ensure there are no metal or magnetic objects near the aircraft and calibrate it before use.(Code: 30060) No SD card. Insert card(Code: 10022)
C00m 01s-0.3 ft0 ftTipSetting new Return-To-Home altitude to 18m (59 ft). Data Recorder File Index is 7. Setting new Maximum Flight Altitude to 120m (394 ft)
D00m 01s-0.3 ft0 ftWarningNo SD card. Insert card(Code: 10022)
E00m 01s-0.3 ft0 ftModeMode changed to AutoTakeoff
F00m 02s1.6 ft1 ftModeMode changed to P-GPS
G00m 14s12.1 ft25 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
H00m 22s16.1 ft45 ftData LossDownlink data connection lost for 2.7 seconds
I00m 25s29.9 ft46 ftWarningNo SD card. Insert card(Code: 10022)
J00m 36s47.6 ft125 ftWarningNo SD card. Insert card(Code: 10022) (repeated 4 times)
K00m 44s60.7 ft90 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
L00m 55s37.1 ft63 ftData LossDownlink data connection lost for 2.9 seconds
M00m 56s34.1 ft61 ftWarningNo SD card. Insert card(Code: 10022)
N01m 03s15.4 ft63 ftWarningNo SD card. Insert card(Code: 10022) (repeated 4 times)
O01m 14s-3.0 ft34 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
P01m 23s-1.3 ft22 ftWarningNo SD card. Insert card(Code: 10022)
Q01m 27s3.3 ft22 ftData LossDownlink data connection lost for 2.7 seconds
R01m 29s14.8 ft22 ftWarningNo SD card. Insert card(Code: 10022)
S01m 51s94.2 ft24 ftWarningNo SD card. Insert card(Code: 10022)
T01m 52s92.8 ft24 ftWarningStrong wind warning. Aircraft unable to return to home automatically. Lower altitude immediately and return to home manually(Code: 30149) No SD card. Insert card(Code: 10022) (repeated 2 times)
U01m 57s85.6 ft23 ftWarningStrong wind warning. Aircraft unable to return to home automatically. Lower altitude immediately and return to home manually(Code: 30149)
V02m 00s65.9 ft23 ftData LossDownlink data connection lost for 3.5 seconds
W02m 09s13.5 ft22 ftWarningNo SD card. Insert card(Code: 10022)
02m 14s2.3 ft22 ft
90% Battery
X02m 14s2.0 ft22 ftWarningNo SD card. Insert card(Code: 10022)
Y02m 25s-1.0 ft139 ftWarningNo SD card. Insert card(Code: 10022)
02m 27s1.6 ft141 ft
90% Battery at maximum distance
Z02m 28s2.3 ft139 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
a02m 33s0.0 ft67 ftData LossDownlink data connection lost for 2.9 seconds
b02m 59s1.6 ft47 ftWarningNo SD card. Insert card(Code: 10022) (repeated 3 times)
c03m 06s-1.6 ft34 ftData LossDownlink data connection lost for 2.8 seconds
d03m 08s0.0 ft33 ftWarningNo SD card. Insert card(Code: 10022)
e03m 23s-3.6 ft49 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
f03m 38s20.7 ft42 ftData LossDownlink data connection lost for 2.7 seconds
g03m 40s12.1 ft42 ftWarningNo SD card. Insert card(Code: 10022)
h04m 11s-3.0 ft27 ftData LossDownlink data connection lost for 2.7 seconds
i04m 13s-2.0 ft23 ftWarningNo SD card. Insert card(Code: 10022) (repeated 3 times)
j04m 19s-3.9 ft16 ftWarningNo SD card. Insert card(Code: 10022) (repeated 3 times)
k04m 26s-4.6 ft17 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
l04m 29s-7.2 ft17 ftModeMode changed to Confirm_Landing
m04m 32s0.0 ft17 ftModeMode changed to P-GPS
n04m 32s0.0 ft17 ftWarningCompass Error
Another example of flight:
A07m 28s0.0 ft0 ftModeMode changed to P-GPS
B07m 28s0.0 ft0 ftTipSetting new Return-To-Home altitude to 18m (59 ft). Data Recorder File Index is 7. Setting new Maximum Flight Altitude to 120m (394 ft)
C07m 28s0.0 ft0 ftWarningNo SD card. Insert card(Code: 10022)
D07m 28s0.0 ft1 ftModeMode changed to Motors_Started
E07m 29s0.0 ft1 ftModeMode changed to Assisted_Takeoff
F07m 30s0.0 ft1 ftModeMode changed to P-GPS
G07m 42s28.9 ft94 ftData LossDownlink data connection lost for 2.7 seconds
H07m 43s29.9 ft92 ftWarningNo SD card. Insert card(Code: 10022)
07m 54s28.9 ft112 ft
70% Battery
I07m 55s29.9 ft113 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
08m 00s30.2 ft114 ft
70% Battery at maximum distance
J08m 00s31.2 ft114 ftWarningNo SD card. Insert card(Code: 10022) (repeated 3 times)
K08m 06s30.2 ft88 ftWarningNo SD card. Insert card(Code: 10022)
L08m 15s44.9 ft82 ftData LossDownlink data connection lost for 2.9 seconds
M08m 15s44.9 ft82 ftModeMode changed to Go_Home
N08m 17s54.1 ft82 ftWarningNo SD card. Insert card(Code: 10022)
O08m 28s53.8 ft16 ftWarningNo SD card. Insert card(Code: 10022)
P08m 33s56.1 ft1 ftModeMode changed to AutoLanding
Q08m 43s18.7 ft8 ftWarningStrong wind warning. Aircraft unable to return to home automatically. Lower altitude immediately and return to home manually(Code: 30149) No SD card. Insert card(Code: 10022)
R08m 45s15.1 ft8 ftWarningStrong wind warning. Aircraft unable to return to home automatically. Lower altitude immediately and return to home manually(Code: 30149)
S08m 48s6.2 ft7 ftData LossDownlink data connection lost for 2.9 seconds
T08m 49s5.6 ft6 ftWarningNo SD card. Insert card(Code: 10022) (repeated 2 times)
U09m 00s-1.3 ft5 ftWarningNo SD card. Insert card(Code: 10022)
V09m 00s0.0 ft5 ftModeMode changed to P-GPS
W09m 00s0.0 ft5 ftWarningMotor is Blocked
Reactions: Mavic Mini
Is the transmission channel mode set to "auto" or "manual"
If its manual you might have previously selected a channel with a lot of interference
Also try refreshing the remote controller and drone firmware
Well, I see it is warning about no SD-card. I don't fully recall but it may REQUIRE a card. I'm not sure if it has any internal storage memory to record anything.
SD card isn't compulsory, but between the SD card warnings it's the "data loss" warning that I am asking about.
Without inserting the SD, you can directly record 720p to your phone.
Thanks, I haven't tweaked any settings so it was on "Auto". The drone was actually manufactured in June 2020 so already updated to the latest firmware (but just in any case I did check it before flying - all of the RC, drone and the flyspot data).
Card not required, display ( phone or tablet ) will record for you
Indeed.
dvkhamtruocsinh
