Drone home repairs? Ugh
Costa Rica Guy
Good morning fellow pilots. I am using the term loosely when referring to myself, since I just flew my brand new drone into a palm tree going upwards! It came crashing to the pavement and appeared to shatter into pieces. HOWEVER...upon closer inspection it appears ok except that one of the rear rotor arms snapped just before the propeller. The drone still starts up and that rotor clicks and all systems say good to fly so apparently all the connections are ok. It is a clean break and no pieces are missing. As you can see by my name, I live in Costa Rica and not sure what my options are here for part replacement. Most likely will order from US and have someone bring down. My question today is....can this be safely glued back and used? Maybe an industrial glue? Any advice ...including " don't even THINK it" ...would be welcome
I've used locktite for many things and on occasions where the item has broken again it hasn't been where its glued, I use
Locktite 431
But 435 is supposed to be stronger
I'd go with Thunderdrones as Flycaster said. I've only heard good things about him and what he does and I would definitely send mine to him if (heaven forbid) I was to ever crash again. Also if you do decide to do it yourself he may have some helpful tips for you. -CF
Meric
