Dubuque Ia : Purchased a 4Pro. Will probably need help
Hello from the Crossroads of America giby.
Nice to meet you Bill. 🤝
Welcome to the Forum. :cool:
Senior citizen. Flew fixed wing for about 50 yrs. Decided to have an aircraft that will come back to me instead of me chasing them..
The tech is a bit overwheming so will need some help at some time.
Glad to be here, tks for any help you can give me.
Bill
The single best source of information and instruction for new drone pilots I've seen is the Pilot Institute. They have some excellent free online courses for drones in general as well as specialized "deep dive" courses on each of the common DJI models.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). If your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. If it weighs more, it has to be registered even if you are flying for fun…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Iowa, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
dansity
