Factory Reset doesn't work
DRONIE.FLIGHTS
Hi, I tried to do Factory Reset, but it didn't work. Any ideas?
If the factory reset fails multiple times in a row, then you should contact DJI support for help. It's likely failing due to some type of hardware issue.
When the update or down grade fails just press the video record button for 10 seconds. Don't restart the mavic and try again should work
Doesn't work. Tryed several times, but same error message as above.
How did you solve your problem?
I experience the same issue "Factory reset failed!"
I am on firmware v 01.03.1000
The Dji support is a bad joke (at least the chat), any help is appreciated.
Reactions: Aktar76
Did you solve it?
Did you solve it?
No, I did not had a chance to use another computer and at the moment the drone seems to work more or less ok...
(Except that the video is either blurry (0,0,0) or flickering (+1,0,0), yesterday suddenly the gimbal moved to 45° by itself and got stuck, I get NFZ warnings but I am not near a NFZ, in sports mode it constantly says "battery overcurrent" and so on... :-D )
I’ve got the same problem can’t factory reset the RC, I also can’t export blackbox data. But I can update the firmware for the RC. I’m currently on the latest firmware and latest assistant 2 software on the computer.
BigPapa98
