Hello all
Today I went out in the Mountains for my first "real" mission and written down some questions which hopefully you can help to clarify :
- as soon as I turned on the AC and RC, a message appeared claiming there were magnetic interferences and I needed to re-calibrate the compass. As far as I understood, if you move in a zone which is more than 100 km far from your previous GPS location, you need to anyway re-calibrate the compass. However I am not sure whether in this case there were "really" interferences (I was surrounded by rocks and ice/glaciers) or just the distance > 100 km applied. any idea?
- despite having checked multiple times I could fly in the area, when I took off I had to manually confirm a warning stating I was flying in a protected area (did not record the message but was claiming something about airports, which of course were faaaar away from the glacier)
- I kept having a look at the receiving signal which was almost always between 4 and 5, but it happened twice that all in a sudden I lost the connection (and some years of life ? ) and the AC forced a RTH with 20/30 seconds of "silence". Is the radio signal similar to the mobile gsm one (which can go away in seconds in the mountains) ? Would in this case a mod (e.g FCC) have helped (just for my understanding) ?
- I was flying over the glacier basin (water), but I did not get any warning about the altitude above water , and since I was a bit below the RTH altitude (hence negative values) I am wondering whether the AC would have just splashed in the water or not ?
- related to the previous question , if I send the drone below the RTH altitude (e.g in a valley), will the drone just apply the RTH altitude (and possibly crashing) or consider also the delta value when coming back?
- is there any way to see at which time the battery was changed in the metadata ? I was very quick in changing them so now have some issues in identifying the right times.
Many thanks to all and have a nice flying weekend from Switzerland
Michele
Michele
