Hi, you who use "floaters" on your Mini2 have you noticed that the lens will be obstructed when you video or taking stillpics straight down? And will the floaters themselves be filled with water afte a while and make the drone go to the bottom?
Hi Zeus! I have not bought floaters yet! Saw this a while ago. I want to be able to regulary land and take off from water.I am not sure what floaters are you using. We have an expert on that topic here. I personally use the rescue jacket that is designed to keep the drone afloat over the water.
In order to prevent the water from going in floaters or even I use that in the rescue jacket I use a waterproofing spray.
I believe this can not be applied by the factory because is flammable and stink making it illegal to be shipped by manufacturers but you can apply that on your own. I am not sure if is approved by @Phantomrain.org but it works for me.
something like this Amazon.com: Sof Sole Waterproofer Spray for Shoes, Boots, and Jackets : Clothing, Shoes & Jewelry
I have floats like the ones you have in your picture..... they do not become waterlogged and work quite well. The trick is to balance them in your sink before trying them outside. The floats are able to be moved forward or back so you have to move them in their brace until the Mini 2 is balanced, then mark the correct location on the float with black magic marker.Hi Zeus! I have not bought floaters yet! Saw this a while ago. I want to be able to regulary land and take off from water.
I use the pontoons if flying over water and they work very well. I have the M2Z and don't really notice any performance issues at all. The only thing I don't like is that it has to be removed and put back on for each battery change because it clamps around the body right over the top of the battery. It's to bad DJI doesn't install several threaded inserts on the top & bottom of these for mounting accessories. The exception is the enterprise model, to mount the spotlight, speaker, and so on. The inserts could be used for landing gear, strobes, etc Something made from metal can always be drilled & tapped but there's not much you can do to these in that regard.Hi, you who use "floaters" on your Mini2 have you noticed that the lens will be obstructed when you video or taking stillpics straight down? And will the floaters themselves be drained with water after a while and make the drone rest on the seafloor.
No performance issues at all?I use the pontoons if flying over water and they work very well. I have the M2Z and don't really notice any performance issues at all.
I've flown with them many times and get about a 2 mph drop in speed, not a big deal to me as I seldom fly wide open. Again I fly the Mavic 2 and it has plenty of power. I have no idea about other models performance with this type of device.No performance issues at all?
That sounds very unlikely.
It's not hard to compare top speed with/without the attached floats.
What is the top speed that you get in normal mode with floatsI've flown with them many times and get about a 2 mph drop in speed, not a big deal to me as I seldom fly wide open. Again I fly the Mavic 2 and it has plenty of power. I have no idea about other models performance with this type of device.
It's at least 6 months since I flown with them, but I think it was 25 or 26 in P mode. But as I said I seldom fly wide open unless I'm doing a demo for someone, it's just not something I do. But am a fairly unusual breed indeed the way it seems, I also try to stay within VLOS. The floats do actually help for that purpose as well.What is the top speed that you get in normal mode with floats
OK .. Without comparing full speed with/without, there are no numbers to compare.But as I said I seldom fly wide open unless I'm doing a demo for someone, it's just not something I do
OkOK .. Without comparing full speed with/without, there are no numbers to compare.
Me too. I am constantly swatting invisible bugs!Hello Photo2be:
I don’t have an answer for you about flying a Mini2 with pontoons - I thought this thread was going to be about all those black spots my old-man eyes see when looking at the sky! Can’t tell you how many times I thought there where crows up there….
Howard
