I have been struggling with this same problem for almost a year but finally I have found a solution. It has been the most frustrating thing given that I bought a Mavic Pro (for a lot of money I might add, Mavic 1, not the
Mavic 2 Pro with the Hasselblad camera) based on the great reviews and the fact that I should have been able to fly and take great footage straight out of the box.
I have trawled all the forums and tried every suggested solution out there with no success, so if you want to know what did and didn't work for me then read on (scroll to the bottom for my solution if you don't want to read the whole post).
My problem began after only a few flights. I live on a tropical island, therefore very high humidity and high temperature. I have seen many suggestions that the cause of the problem is somehow environment related. It is not acceptable in my opinion that such an expensive machine would have a fault that renders it useless in certain environments, if that were the case we should all be made aware of this before handing over our money. In any case I have seen many reports of this happening in climates hot and cold, so it is not a climate or temperature related problem.
Here are the suggested solutions I found and what happened when I tried them, and some I came up with myself:
1. Store the machine (and carry bag) in a sealed bag with dessicant for several days (tried silica gel packs and rice). Result - no improvement at all, camera still fogging.
2. Drill very small vent holes in the side of the camera case to allow moisture to be drawn out by the dessicant or to ventilate during flight (was already at a dead end by this point so nothing to lose). Result - dead camera. See attached photo of a dismantled camera, very tightly packed and I'm assuming I contacted something inside with the drill bit.
3. Buy a new camera - I bought five replacement used cameras (quite cheap on ebay). Result - the cameras arrived in greatly varying condition, only one didn't have any scratches on the lens, one didn't work at all, another had a shattered lens inside, three worked properly, of which one I'd describe as being in excellent condition. Of the ones that worked, all were fine fogging wise to begin with, but after a few flights every single one of them then developed the same fogging problem. I therefore came to the conclusion that this is a fundamental flaw in all Mavic cameras, and the problem is guaranteed to appear sooner or later in certain environments.
All Mavic cameras are not well sealed, and once moisture gets in it's very difficult to get it out, and even once dry the problem will come back again sooner or later. I decided I wasn't simply going to keep buying replacement cameras and then throw them away once they started fogging after a few flights, so I dismantled one of the disfunctional cameras to see what was going on inside (see attached photo). There is a seal under the circuit board which clearly is not fit for purpose.
4. Seal a replacement camera around the edge of the circuit board with silicone before it has a chance to fog. Result - dead camera. I'm not completely sure why, but looking at the attached photo you can see some of the blue silicone actually seeped through the seal under the circuit board (yes the one that's supposed to stop individual water molecules getting in, it couldn't even stop a large blob of silicone getting in!). I'm assuming the camera didn't like silicone where it eventually got to inside.
5. Put the entire machine in the oven to dry it out. Are you crazy!!? I've seen this suggested a couple of times, but there's no way in hell I'm putting my whole machine in the oven, plastic and all. Based on all my experimentation, this would be a guaranteed way of quickly killing your investment. Feel free to try but it's actually very easy to remove the camera and attempt to dry it out separately.
6. Dry the camera in the oven. I only have a gas oven, and gas gives off moisture. So I suspended the camera from a wire in a pan and covered it to create a mini oven on the hob. On the lowest heat possible I left it for a couple of hours. Result - dead camera. Obviously the temperatures in cooking appliances are too high and will kill your camera.
7. Staying on the cooking theme, here is the only thing that has worked for me:
Equipment
1 x medium baking tray
1 x heat gun
Ingredients
Appox. 1kg dry basmati rice
Spread the rice out in the tray about 1cm deep. Slowly run the heat gun over the rice until it is too hot to pick up and hold but still cool enough to touch (not sure exactly what temperature that is). I'm sure a hair drier would work just fine too, it would just take a bit longer. Remove the camera from the machine and place it on top of the rice, then take handfuls of rice and pile it in a mound on top. Leave that until the rice has cooled, it will stay warm for an hour or two. This has the effect of both gently heating the inside of the camera to drive the moisture out where it is then captured and wicked away by the very dry rice. I did this five or six times and then left it overnight in the mound of rice. Result - no fogging!!!!! The camera worked perfectly so the temperature was obviously hot enough to drive out the moisture but not too hot to kill it. I did three consecutive flights with crystal clear footage, something I have not achieved since the problem first appeared. I don't know yet how long it would take before the problem appears again, but I intend to store the machine and carry bag in a sealed bag with my 1kg of ultra dry rice to delay the onset as long as possible. I'm also waiting for a couple more replacement cameras, which I will subject to the same treatment, so the worst case scenario is I have to quickly swap cameras if the fogging returns at an awkward time.
I hope this is of help to those of you frustrated by the same issue with seemingly no solution. If you try it and it works for you, feel free to copy and paste this anywhere you choose so that others might actually be able to use what is otherwise a fantastic machine.
Brief update - I have now completed eight full flights with no fogging at all so it would appear I have managed to get rid of most of the moisture in my camera, and now I see my challenge as stopping it building up again.
I've made another interesting discovery in that regard. I've just subjected my DJI carry bag to the warm rice treatment, this time inside a large sealed bag. After only 10 minutes there was a large buildup of condensation on the inside of the plastic bag, and being sealed, the only place that water could have come from is the carry bag. It's basically a big sponge and I suspect much or all of the water in my camera got transferred in there from the carry bag while not in use.
So the last piece of my solution is to completely dry the carry bag by my now much liked warm rice method, and from now on I will be storing everything (drone, controller, phone, carry bag) inside the sealed bag with the rice, and every so often I'll repeat the heating of the rice to make sure it stays completely moisture free.
I really hope this helps others fix this rather ridiculous problem, as you can see it's been a very long and frustrating process for me. If reading this helps anyone else not waste their time going through the same trial and error process I did then I can feel happy I've done my bit for humanity.
