- Joined
- Jan 21, 2019
- Messages
- 13
- Reactions
- 16
Any tips to make the snowlandscape more vivid (settings in the Mavic Air)?
So white balance, any recommended value?There are some tips here - 15 tips if you want to fly in the Snow
I read somewhere to up your white balance in the snow but I have no experience. Someone will be along that knows more than me.So white balance, any recommended value?
Which ND filter should be used?
You do not need to use an ND filter. You can white balance using your screen to see what makes the snow look the closest to what your eye sees. You may have to manually adjust your aperture settings though because the light sensor will think you have more light than there really is. Therefore, you will be getting rather darker images than you may want. So, basically you may have to open up a little more than what the light meter is telling you it should be. Shooting darker subjects, you often have to go the other way and stop down a bit to get a correct exposure.So white balance, any recommended value?
Very nice, what was the music please?Any tips to make the snowlandscape more vivid (settings in the Mavic Air)?
thank youYou do not need to use an ND filter. You can white balance using your screen to see what makes the snow look the closest to what your eye sees. You may have to manually adjust your aperture settings though because the light sensor will think you have more light than there really is. Therefore, you will be getting rather darker images than you may want. So, basically you may have to open up a little more than what the light meter is telling you it should be. Shooting darker subjects, you often have to go the other way and stop down a bit to get a correct exposure.
Scott Buckley - 'Stars In Her Skies'Very nice, what was the music please?
