From Huntsville, AL
bwilson4web
Huntsville, AL
New DJI Mini 3 owner, it has been great to compliment my Solar Project. For example, taking a shot of the house every hour over a day identified where to capture morning and evening light. It also identified trees that had to go.
After installation, I'll use it to inspect the panels including looking for bird nests and other debris. At age 75, I don't look forward to climbing a ladder to the roof. But one question about the JPEG files.
I love to see the GPS and altitude components BUT there is no azimuth, which direction the drone is facing. Is there some configuration option to turn this on or do I need a higher class of drone?
Bob Wilson
Hello from the Crossroads of America bwilson4web.
Nice to meet you Bob. 🤝
Here's a link to the user manual that may be helpful in the future.
Page 50 , item 17 talks about the map in the lower left corner of the flight screen that shows the orientation of the aircraft during the flight.
Once you understand how it works, it is useful.
Here's a video from a few years ago when a change was made in the app that may help.
Good luck and welcome to the Forum. :cool:
Hi Bob,
DJI drones record orientation of drone and drone's gimbal into images. Look for "drone-dji" in the image metadata. Here's an example:
<drone-dji:AbsoluteAltitude>-71.65</drone-dji:AbsoluteAltitude>
<drone-dji:RelativeAltitude>+51.30</drone-dji:RelativeAltitude>
<drone-dji:GimbalRollDegree>-0.00</drone-dji:GimbalRollDegree>
<drone-dji:GimbalYawDegree>+73.84</drone-dji:GimbalYawDegree>
<drone-dji:GimbalPitchDegree>+0.27</drone-dji:GimbalPitchDegree>
<drone-dji:FlightRollDegree>+4.00</drone-dji:FlightRollDegree>
<drone-dji:FlightYawDegree>+47.50</drone-dji:FlightYawDegree>
<drone-dji:FlightPitchDegree>+4.00</drone-dji:FlightPitchDegree>
<drone-dji:CamReverse>0</drone-dji:CamReverse>
<drone-dji:GimbalReverse>0</drone-dji:GimbalReverse>
Hey, I'm not far from you in Middle Tennessee. And I was just in Huntsville a couple of weeks ago. Sure love Rosie's Mexican food.
You may want to explore waypoints. I'm pretty new to them, but noticed on my Mavic 3 Pro that the info you're wanting is included with each waypoint. If you could set waypoints, then offload them to your PC, you might have what you want.
Happy Flying!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3, including the User Manual.
Fly On and Fly Safe…
Bob Wilson
A big welcome to the forum from the UK!
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members who are willing to help you with any questions you might have. Search the forums using keywords and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response!
Fly safe, enjoy and stay safe!
osje
