Greetings from Czechia (Czech Republic)
coolboxgames
Prague, Czechia
Hello to everyone. I'm a total beginner. :)
Learn to fly, learn to make videos etc.,
My drone is DJI Mavic Air2.
Since I don't play video games, joystick controls are not close to me, but I practice - my son, who grew up playing video games, laughs at me.
In any case, flying a drone is an addiction and a hobby, and I'm glad that I found this forum where I can ask questions (yes, I'll check first if there isn't something that would answer the same for me)
Hello from the Crossroads of America coolboxgames.
Me too.
Since you're flying an aircraft and not playing a game, pay attention to the controls.
You don't get to "reset" and get a new drone every time you fail.
On the topic of joystick control, pincher or thumber?
A majority of pilots / gamers rest the thumbs on top of the joysticks.
If you pinch the sticks at the top with the thumb and forefinger, you may have better control of the aircraft.
Good luck and welcome to the Forum. :cool:
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I sure you’ll get a quick response! Fly safe and stay safe!
Since you live in Czechia, there are specific laws and rules for you to follow, please check to ensure these are current.
Úřad pro civilní letectví - Bezpečně a s nadhledem
The Local Language version…
Civil Aviation Authority of the Czech Republic
the English version…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air 2, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
JefScot
