Greetings from Eastern North Carolina
Hello from the Crossroads of America FlyinMike
If you havent done it yet, swing by and take the TRUST test to keep a copy with you when you fly.
Here's a link to some of the chatter in N.C.
There's also a members map link at the top of the page but not sure if it's working properly at this time. 🤔
Welcome to the Forum. :cool:
Thank you for the welcomes. I completed my TRUST card and Drone registration as soon as I had the S/N for the drone.
How To videos were very helpful. Between working 5 1/2 days a week and going to class 2 nights my air time is limited, but I will make more flights as my trust in my own abilities increases.
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
After reading the manual and a lot of posts here I finally let my Mini 3 take flight. Nothing fancy, just s few short runs and letting it teach an old dog new tricks. I really enjoy reading the forums and thank everyone for their contributions.
Are there any organized gatherings (fly-ins) in the state
Welcome from right down the road in Savannah!! Whoop Whoop!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome from western NC
stephy_gl
