Just purchased a new Mavic Mini 2 Monday. I almost purchased the Air 2S but figured if I crash and burn the Mini 2 I'll only be out half the cost. I'll upgrade later if I don't auger this into the ground.
Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!Just purchased a new Mavic Mini 2 Monday. I almost purchased the Air 2S but figured if I crash and burn the Mini 2 I'll only be out half the cost. I'll upgrade later if I don't auger this into the ground.
I used to live west of COS. The house was at 9,000 ft. I miss the mountains. And low humidity.Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
I'm up in Estes Park and our house is at 8200ft. Love the cooler temps up here even though its going into the 80's here today. That's hot for us up here. I'm also not a fan of humidity, at all. Been to Biloxi in the summer and also lived in Arkansas as well as Florida. I'll take the mountains and cooler temps any over the heat and humidity.I used to live west of COS. The house was at 9,000 ft. I miss the mountains. And low humidity.
I just noticed your little bio about retired ATC. Same here. 5 yrs at COS. 22 yrs total before retiring.Welcome to the forum from the Rocky Mountains of Colorado! Happy and safe flying!
Using the term "auger in" is 22 years of air traffic control in me. My only previous drone prior to this new one was a cheap lightweight pita I bought in 2016 to get a feel for drone flying. The footprint for it is about 4 times the Mini 2. It was very prone to being pushed by light wind. I have a little over 2 acres here with a good size open backyard. I've had it out there practicing. Lots of room. The Mini 2 is so much better to fly.Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Members map
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.trust.pilotinstitute.com
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
FAADroneZone
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Online Ground School: Aviation Classes - Pilot Institute
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.pilotinstitute.com
Since you live in Mississippi, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Drone Laws and Best Places to Fly in Every US State - Pilot Institute
pilotinstitute.com
Because you have not flown Drones before, here is some Good Old Fashion Advice…
PS: I have a Mini 2 and it is exceptionally difficult to "Auger it into the Ground…", it is much easier to "Spike a Tree, Trim the Bushes, or Ram the Wall of a Building."
Since you do have these fears of destroying your little bird, go out to a wide open area, large lot or park (no trees or people, or obstructions) and crank your little bird up and as you pass some visual point of reference (ie: telephone pole, etc…), just release the sticks and see how quickly your little bird stops and note where it stopped. Now go back and do it again, this time, as the drone passes the visual reference, push it into full reverse. I think you will see little difference in the stopping distance.
Also as a Newbie, here is a link to a Great YouTube Video that teaches 15 Drone Maneuvers for Beginners…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Great photo of your birds...Using the term "auger in" is 22 years of air traffic control in me. My only previous drone prior to this new one was a cheap lightweight pita I bought in 2016 to get a feel for drone flying. The footprint for it is about 4 times the Mini 2. It was very prone to being pushed by light wind. I have a little over 2 acres here with a good size open backyard. I've had it out there practicing. Lots of room. The Mini 2 is so much better to fly.
