Greetings from Phitsanulok, Thailand
SupermaNZ
Nong Kula, Bang Rakam, Phitsanulok, Thailand 65140
Hi Team
I'm a retired Kiwi living in Nong Kula, Phitsanulok. I've been flying a DJI Mini 2 in Thailand for a couple of months, and have just purchased Litchi for Mac - looking forward to using it soon.
The Mini 2 is superb. I have no idea what I'm doing - but it's loads of fun!
Ciao
Fergus
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Living in Thailand means you had better obey their rules and laws… Here is a web site to help you…
Now for some good old fashion advice…
Below is the link to all of the downloads offered by DJI for the Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
JefScot
