Greetings! New member just saying hello.
Rayder1
USA
Hello....just staring in the drone world. I am already a semi-professional ground based photographer (meaning some paid gigs)and am really impressed with the view and still quality in my starter drone. (Mini 2 SE). I didn't want to dive deep until I have the basics down. Now that I do....I will likely move up in the world. Still just playing and taking cool aerial shots and videos. Now I will use this forum to gain further insight, tips and tricks. Today was foggy so I sent my drone up above the pre-set limits to explore above the fog bank. I use a flight radar program so I know where the local aircraft are flying IFR and knew it was clear in my area. It was really impressive.I didn't move about since I didn't want to stroll into controlled areas, but there were some really beautiful above the fog shots to be had.
Looking forward to seeing some discussions and tips!! Take care
Ray, Clovis CA
@Rayder1 welcome to the forum
i will be frank with you ,your first post ,did not sit well with me ,two things really stand out
(1) i sent my drone above the preset limits ,was that the 400ft AGL limit you are refering to
(2) i flew above the fog bank, so could you still see the drone
sorry if my post offends you ,but airspace rules are for the safety of all users including us
Welcome to the forum! :)
Welcome to the forum!.
"I use a flight radar program"
Is this like
Or something I don't know about?
Rod ..
Warning, you listed your location as USA and you apparently live in California, so the Map may not show you in your location, but you can scroll over to it…
I'll start right off, flying above the FOG is illegal, and the FAA forbids it, so be cool, learn what safe and legal and you'll stay out of trouble… I am not a NARC, just letting you in on the truth…
Now, back to having fun…
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in XXXXXXXXXX, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini SE, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum -looking forward to hearing more from you!
If you are using a new program Please share the name. I have YET to see one of these that are actually accurate.
FLY safe, Head the above advice- and keep us posted of your droning adventures!
Welcome to the forum from the beautiful woods of Maine!
I have to agree with Old Man Mavic, please complete Trust and familiarize yourself with all the rules regarding both recreational and 107 flights.
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome from Vero Beach, Florida. We are all one happy family.
Ray, Clovis CA
Welcome to the forum from the Colorado Rocky Mountains. Happy and safe flying!
JefScot
