Is Exif data rates somewhat accurate? I was actually trying to do a normal/D-Cinelike comparison test, and my 4k h264 30fps cinelike shows 87mbps on exif, while the same config non-cinelike is showing 92mbps. It doesn't make much sense. In mediainfo both show the same 93mbps.H.265 should be able to do 4K 60fps with about the same file sizes as H.264 30fps. Are you sure both are 30fps? What does the EXIF file show for data rates?
Sorry, didn't mean EXIF (still not finished first cup of coffee); it's in the MP4 or MOV headers. Anyway, if H.264 and H.265 are encoded with the same bitrates, then as (EDIT) Kilrah said, the H.265 will be higher quality. Does the Mini 3 provide any way to specify video quality?Is Exif data rates somewhat accurate? I was actually trying to do a normal/D-Cinelike comparison test, and my 4k h264 30fps cinelike shows 87mbps on exif, while the same config non-cinelike is showing 92mbps. It doesn't make much sense. In mediainfo both show the same 93mbps.
The same but h265 also shows the same in mediainfo (91mbps in exif).
I used LosslessCut to cut all clips to the exact same length (5s) and the all of them became 56MB files (slightly different exact numbers).
And BTW, the 4k h265 60fps became a 93MB file, with media info showing 153 mbps.
No, target bitrate is constant.higher ISO = more noise = larger files
H. 265 is 10bit VS H. 264 at 8bit. There is more data in an H. 265 file of the same frame rate.
So, you're saying DJI's (or really, Ambarella's) implementation doesn't support the H.264 "High 422" profile? Perhaps you're right, but I'd be surprised, and I can't seem to find any reference to confirm or deny that.What I am saying is if you want 10bit video on the Mini3 you need to use H.265 as the H.264 codec will not support it.
