Today the mini drew first blood, my arm is pretty messed up.
I'm not sure what happened so figured some advice could be useful.
I was flying the mini outside, controlling it from a window of the first floor of a building.
When I was done flying, I brought the mini very close to the window so that I could place a flat hand about half a meter below the mini.
Then I pressed down on the joystick so that the mini would slowly land on my hand (I do this regularly).
Instead what seems to have happened is that the downward facing sensor had no clue my hand was there.
The mini therefore descended rapidly onto my hand, I got scared and pulled my hand back inside the window with the mini on it and then things got a bit out of hand (literally ) until I managed to shut off the engines.
Is the procedure for hand-landing that I followed not the right one? Did I just have very bad luck that exceptionally the sensor didn't spot my hand?
Some of the blades also got a bit damaged in the accident. This is the worst one, it seems to fly allright, but it now makes a different noise than the other blades when flying. I guess it's not too damaged to fly?
