I'm a total newbie to drones. I have just got an
Air 2S and I'm getting use to it. Are there any more on here from Ireland?
Welcome from the Hampton Roads area of Virginia, USA. You asked if there are any more from Ireland, the Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Since you live in Ireland, there are specific laws and rules for you to follow, please check to ensure these are current.
According to IAA, drones are allowed in Ireland, subject to IAA and EASA regulations. Read on for details.
drone-laws.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
At DJI Download Center, Learn aboutMavic
Air 2
www.dji.com
Happy, Safe and Legal Droning…
