Welcome from the Hampton Roads area of Virginia, USA. I am a
Mini 2 Flyer and I know the excitement of flight. So, if I may offer some advice.
If you are in the U.S.A. there are a couple of Legal Things you need to do… Register your Drone, that can be done at the FAA Web Site. You also need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) .
FAADroneZone
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
If you live in another country and are fly there, be sure you are following all of the laws and rules applicable to you.
Below is the link to all of the downloads offered by DJI for the
Mini 2. You will also find the 75-page User's Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 2 - Download Center - DJI
Happy and Safe Droning…
