Hello from the beautiful Tennessee River
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
Hello from the Crossroads of America Steve-Oh
Now I don't feel so bad about crashing the first one.
What was the first one?
Mine was the Spark.
Still flies fine, but it has a wonky view of the world due to a gimbal problem. 🙃
Welcome to the Forum. 😎
This is my second drone. It's a Mavic3 and I've really been enjoying it a lot. Now I don't feel so bad about crashing the first one.
Welcome to the forum from the windy Colorado Rockies! Happy and safe flying!
As a Fairly New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Tennessee, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
So, before you get a chance to crash your second drone, here is some Good Old Fashion Advice that may save you from repeating…
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Happy Droning…
Happy Droning…
LOL, Now, When you register your drone.... and you crash you might have to notify FAA and NTSB comes out and investigate :) As it is an Aircraft same as a Boing 747... Drones come with some responsibilities now days.
Happy Droning.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Colinhayesroberts
