Hello from the NC/SC area
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my Mini 2 under Part 107.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in the Carolinas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Thanks so much for your help! I've already done most everything mentioned and studying now for Part 107.
So much knowledge here and on the web, and I'm trying to take it all in. 3D mapping is something I'm interested in, so I'm studying it a lot. Been doing photography and video for years but now taking that to drone work and, hopefully, a new career.
Thanks again!
Reactions: LoudThunder
Baby Steps... Studying for the Part 107 should be a full time effort (behind your job, your family, your life...). Once you pass the 107, you will still have time to study mapping, A Community College course on mapping goes a long way with knowledge and experience... Many community colleg3es are getting into Unmanned Aircraft Systems (UAS) and even offer certificates in the course of study...
Good Luck!
Reactions: wjkrysak
Robby1983
