Just got my first drone (
Air2 S) and getting used to flying it around. Can’t believe how manoeuvrable it is! Looking forward to finding a decent manual for it, along with all the posts here.
mavicpilots.com
Your Wish is my command, at the end of this posting is a link to all the downloads, including the DJI User Manual… Now, don't you wish you asked for a Million Dollars instead of just a manual? But to really see all the capabilities of your little bird, watch lots of YouTube Videos…
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
You can fly a drone in Australia for recreational and commercial use, subject to CASA regulations. Official links and Australia Drone Laws explained for residents and visitors, hobbyists, recreational, commercial and government drone flyers.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic Air 2s, including the User Manual.
Learn and download
Mavic Air 2 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
