Hi from San Francisco
Just picked up a Mini 2 fly more kit on Craigslist from someone who bought a 3 Pro. It’s my first drone and I’ve been doing a few training flights, but SF is pretty locked down. I quickly found that I lost sight of the little mini, so hoping this wrap helps with that.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Oh, you put a RED Wrap on your little baby, Since you are in California, you just forgot the Sunblock… LoL
In your part of the country. California, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in California, there are specific laws and rules for you to follow, please check to ensure these are current.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Thanks — did the Trust exam and registered the same day I got the drone, then got up to speed
took care of the TRUST exam and registered it the first night, then started looking at all the local restrictions (CA, SF, GGNRC).
My dog hates it.
My dog hates it.
Whatever you do, do not tease your dog with it. You might come home one day and find out that your dog turned it into a chew toy…
Here is some more dog advice, if when you are out flying and you are in a public area, like a park, and a loose dog takes an undue interest in it. Do not believe the dog owner that the dog is only curious. The dog wants to eat it and may bite you if you try to hand catch it to keep it away from the dog.
While you still have good battery reserves, now you tease that dog and "take it for a walk/run" off to a far off section of the park. Make the owner run after the dog trying to catch it, then when the dog is a good ways away, climb baby, climb, and when you are up a couple of hundred feet, the dog will lose sight of the drone and you scoot back and land. The dog will be long gone and the owner will still be chasing their dog…
But as for your own dog, don't give it a reason to chew it up…
robava
