Hi from the Basque country
Welcome to the forum! :)
New user here, trying to learn mapping using a Air 2s.
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Fly On and Fly Safe…
Hello from Minnesota and welcome to the Forum....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
dugan
