Been flying a hand me down GoPro Karma for a while had to upgrade when it fell out of the sky all by itself . So now have just purchases a DJI
mini 3 pro
mavicpilots.com
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
Even though you have been flying Drones before, here is some Good Old Fashion Advice considering you have a new "Baby" that flies vry differently…
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
