Ok what would it look like? I'be seen a bright light that was always in the same spot but it moves. I've also red and green flashing light.You'd need to see it. At night this would be aided by lights. No extra lights displayed while taking a photo.
Helicopters also have flashing red and green lights but are much brighter so you are much more likely to see that at distance. Sometimes it can be possible to see a drone and mistake it for a helicopter that’s far off in the distance if you don’t know what to look for. Vice versa.Ok what would it look like? I'be seen a bright light that was always in the same spot but it moves. I've also red and green flashing light.
My avatar is my MA with Firehouse lights. In the photo they are not in the strobe but are very bright.How could I spot a drone in the night sky? Also is there a flash when they take pictures?
Thank you for your help!
Ally
It works even better if you wrap your head in tin foil, that way the drones can't change your mind.If you put tin foil up in your windows it will cause the drone crash when it takes a picture of you. The lights reflection triggers the collision sensors to cause a forced landing. I covered my mini blinds in foil so I can close them quickly whenever I hear that familiar buzzing sound.
I'm pretty easy to seeHow could I spot a drone in the night sky? Also is there a flash when they take pictures?
Ally
funny..love it.I
did it look like this?Ok what would it look like? I'be seen a bright light that was always in the same spot but it moves. I've also red and green flashing light.
If anyone catches someone with a drone that has duct tape covering the nav lights has my permission to give the pilot a good ole fashioned beatdownIf someone is spying on you the lights will have been made invisible.... duct tape for example.
Don’t worry.
lolIf you put tin foil up in your windows it will cause the drone crash when it takes a picture of you. The lights reflection triggers the collision sensors to cause a forced landing. I covered my mini blinds in foil so I can close them quickly whenever I hear that familiar buzzing sound.
I have a video that I'm not able to upload for some reason? Here's another picView attachment 81992
My Mavic Pro at night...
I'm guessing the number of UFO reports skyrocketed in your neighborhood...I have a video that I'm not able to upload for some reason? Here's another pic
Lol,i have several dji drones i have lights for but my favorite is my phantom 1 with leds that circle it vertically and horizontally that had people pull over and scream look its a ufo,ill look for that pic and send it when i find it.I'm guessing the number of UFO reports skyrocketed in your neighborhood...
I agree Tom, appears like someone joined the community out of paranoia. . . .If someone is spying on you the lights will have been made invisible.... duct tape for example.
Don’t worry.
I'll look for that info when I get home tonight,it was from Amazon I search for led prop guards and that popped upWhat lights did you get for that?
