Thank you, why the mini 2?
I have used iPad mini 3 before (which is the same as iPad mini 2 but without fingerprint scanner) and it works fine. I'm not so sure now though if it will work the same as before.
Thank you for your suggestions. The only thing this tablet will have on it is the DJI go4 app, nothing else so hopefully it will be satisfactory. In the mean time I'm using a Galaxy S7 edge which works great.
Great reply, I appreciate it.My situation is very much like yours. I was quite happy with the Galaxy S7 but, after reading many posts about the benefits of having a bigger screen, decided to spend $25 on a Pad Holder to mount my 9.7” iPad Pro which works perfectly.
If I didn’t already own the iPad Pro I would have waited a few months for the upcoming iPad Mini 5. The advantage of using the iPad Mini is twofold - it’s much lighter and you don’t need a bracket to mount it on the RC.
hi, newbe here. I read your post and I’m a little confused. I just receive my Mavic Air last week. I have an iPhone 7 and I can’t see how anything larger can fit into the controller. Do you control your Air with the iPod only? I’m in New England, cold and wet, so I haven’t flown outside my living room.
Yes, one of the reasons I'm not sure if the iPad 2 or 3 will work anymore because the app keeps updating. Some updates on the app require higher system requirements. Not sure if the iPad 2 can still meet the minimum requirements.Is that because of the GO app being updated?
