Ipad mini 2 wont
Flytelandon
Belleville, ontario
I have mavic mini with Ipad 2 mini, cant view view the whole screen, cuts part of screen off and wont allow me to X out of the menus? Can someone explain how I may get to fix this? Thanks in advance
have you tried to scroll with your finger on the screen
will it scroll sideways ? or just touch the home button see if it works
Is 2x mode enabled on iPad? Before the full screen resolution wasn't supported on iPad, so we all used the expand to fit feature. Perhaps latest version now supports iPad resolution.
Does the app actually work (fully) with iPad 2 mini?
I think I saw somewhere perhaps on this forum that iPad 4 mini was a minimum requirement as regards OS for M2 Pro and Air and I assume MM. What version of OS have you got on iPad 2 mini?
Where do you even go to download the DJI Fly app onto the ipad 2? On the app stores, when I click to install, it says it's not compatible.
It says it is incompatible because it is unfortunately. It isn't powerful enough to run Go 4. Look here for an appropriate DJI thread on this. AFAIK you need at least an iPad Mini 4.
Reactions: Brevanskc
kotszamana
