Left and right Gimbals movement with left/right rudder control
altereddezignz
While i was doing a video test on another issue with sharpness i had the mavic setting on my porch and i hit the rudder control and noticed that my screen moved?
So i tried it left and right with it setting flat on concrete and the gimbal and camera moved with the rudder input on the left stick??
Is this supposed to happen this way?
( Forgot the Video.... Rookie Move!!! )
Thanks. I had no idea and it just seemed a little odd to me other than maybe to counteract the movement of the drone in the air.
Actually you are correct. Yaw movement of the aircraft is very swift, there for the gimbal is designed to smooth the sudden jerks left or right. It does this by communicating with left and right yaw from the input of your left stick.
This is to insure you get better or smoother video.
Reactions: altereddezignz
Thanks for the info. I had an assumption it might have something to do with that but wanted to make sure. now back to the search for the perfect video and stills settings lol
kencunm
