Litchi on Moverio BT300 glasses.
Same here 4.10.0-a from Amazon working great in ground test on Mavic Air and Pro - not yet flight tested but looking good. Was never able to enter FPV with previous versions.
Davo.
The Amazon store now has Litchi 4.11 not 4.10. I tried to install 4.11 last night and while it loaded and opened fine, I wasn't able to see the camera view. It was just a black screen. But it didn't say disconnected like it used to.
Has anyone installed the latest version (4.11) and got it to work on the Moverios? Also does anyone have a good site to get the older 4.10 version.? After doing a google search for Litchi 4.10 apk the options that are available give bad files - none of then worked.
Has anyone tried the 4.11 version yet. I am afraid to update from the 4.10.0 version because I know that that version is working great.
I have same problem. Grrrrrr. Downloaded 4.11 and black screen.
I'm running version R 1.5.0 for firmware and double checked that the Litchi is indeed version 4.11.0a
hope that helps.
Thank you for information
Did you do any special settings or all default
Because I have same versions of firmware and
Litchi and it is connecting to my drone but no image from camera
No special settings. Camera and maps all work fine as does the Birdseye view
Here are the files you need to copy over to the BT-300 and install
Dropbox - 3Rd Party Ap
Order of install is
Google play services
Google play info
Google play store
Maps Navigation Transport
Litchi 4.0.2 (this is only version that works at the moment)
Litchi for DJI Drones 4.0.2 Patched - APK Home
Very greatful lannes. I tried the Dropbox link but been 2024, it no longer exists. I am so excited implementing this legacy Moverio to my Legacy DJI Mavic Pro. Keeping reading on and on. Thank you from the Caribbean Sea, and Puerto Rico 🇵🇷.
Order of install is
Google play info
Google play store
humbly, as a novice w/ Eoson Moverio BT-300; how do I install? Because I downloaded APKs via browser and apkpure or apkhome and I get a "parsing error". I do not know how to sideload on neither Samsung or Moverio. Thanks in advance.
YT360
