Litchi waypoints, if I start from an elevated position
Jonny63
Starting from an elevated position does the drone maintain its home point height or height relative to the ground. Do I need to put in a negative height to descend.
From the home point. Below your initial ground start point - Yes.
Fly the route manually first, just to be sure you have everything correct. Or try it while making sure to take over if needed. But flying too high is always good. Flying too low - generally not.
Lahki
